Saltar al contenido principal
Apple Cinema Display M8149 USB Port Replacement
Qué necesitas
  1. Apple Cinema Display M8149 USB Port Replacement, USB Port: paso 1, imagen 1 de 3 Apple Cinema Display M8149 USB Port Replacement, USB Port: paso 1, imagen 2 de 3 Apple Cinema Display M8149 USB Port Replacement, USB Port: paso 1, imagen 3 de 3
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Apple Cinema Display M8149 USB Port Replacement: paso 2, imagen 1 de 3 Apple Cinema Display M8149 USB Port Replacement: paso 2, imagen 2 de 3 Apple Cinema Display M8149 USB Port Replacement: paso 2, imagen 3 de 3
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Once the screws are removed, lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. Apple Cinema Display M8149 USB Port Replacement: paso 3, imagen 1 de 1
    • Unscrew the USB cable routing screw (8 x 2.72mm) using the PH 2 screwdriver.
  4. Apple Cinema Display M8149 USB Port Replacement: paso 4, imagen 1 de 1
    • Unplug the USB cable connector from the screen box.
  5. Apple Cinema Display M8149 USB Port Replacement: paso 5, imagen 1 de 2 Apple Cinema Display M8149 USB Port Replacement: paso 5, imagen 2 de 2
    • Using the PH 2 screwdriver, unscrew the two screws (4.85 x 2.94mm) on the USB ports.
Conclusión
Kyle Suguitan
Miembro Desde 04/01/11
21 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-41, Forte Spring 2011 Miembro de Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 4,422
