Saltar al contenido principal
Apple AirPort Extreme Model A1354 Back Pad Replacement
Qué necesitas
  1. Apple AirPort Extreme Model A1354 Back Pad Replacement, Back Pad: paso 1, imagen 1 de 1
    • Caution: the back pad is secured with glue so remove it gently to avoid ripping the pad. You may have to repeatedly pull and release to loosen up the glue.
    • First start by peeling off the outer rubbery covering on the bottom of the device. This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
    • Continue peeling back on the pad until it is removed.
  2. Apple AirPort Extreme Model A1354 Back Pad Replacement: paso 2, imagen 1 de 1
    • Place double sided tape along the sides of the bottom of the device as shown, this will allow for the rubber cover to stick back on but still be accessible in the future
    • Repeat steps for all four sides
  3. Apple AirPort Extreme Model A1354 Back Pad Replacement: paso 3, imagen 1 de 1
    • Line up rubber cover along the bottom of the device.
    • Press down firmly to secure the rubber cover onto place.
Conclusión
To disassemble your device look at device disassembly on the main page.
2 personas más completaron esta guía.
Alex Ly
Miembro Desde 04/02/12
201 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 5-2, Forte Spring 2012 Miembro de Cal Poly, Team 5-2, Forte Spring 2012
CPSU-FORTE-S12S5G2
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 3,036
