Introducción
The Wi-Fi card failing in your device would cause the device to power on normally, but not transmit the internet connection to any other devices. Luckily Apple has made this component easily accessible and quick to change.
Qué necesitas
Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
Remove logic board and metal casing from outer case by prying from one side using a spudger.
Herramienta utilizada en este paso:Tweezers$4.99
Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
Carefully push back the three metal tabs with your fingers on the sides of metal case.
Locate the WiFi card on the logic board, then use the prying tool to bend back the plastic holding it in place.
After holding back the plastic piece keeping the card in place, lift the card up and pull it away from the logic board.
2 personas más completaron esta guía.
