Saltar al contenido principal
Apple AirPort Extreme Model A1143 Battery Replacement
Qué necesitas
  1. Apple AirPort Extreme Model A1143 Battery Replacement, Back Pad: paso 1, imagen 1 de 1
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. Apple AirPort Extreme Model A1143 Battery Replacement, Back Cover: paso 2, imagen 1 de 1
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Battery Replacement: paso 3, imagen 1 de 1
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Battery Replacement, Remove from Case: paso 4, imagen 1 de 1
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
  5. Apple AirPort Extreme Model A1143 Battery Replacement, Detach Logic Board From Case: paso 5, imagen 1 de 1
    • Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
  6. Apple AirPort Extreme Model A1143 Battery Replacement, Pull Back Tabs: paso 6, imagen 1 de 1
    • Carefully push back the three metal tabs with your fingers on the sides of metal case.
  7. Apple AirPort Extreme Model A1143 Battery Replacement, Remove Metal case: paso 7, imagen 1 de 1
    • Carefully pull the metal case away from the logic board.
  8. Apple AirPort Extreme Model A1143 Battery Replacement, Battery: paso 8, imagen 1 de 1
    • Gently slide out the battery with a small narrow tool such as a spudger. Insert a new 3V CR2450HR.
Conclusión
6 personas más completaron esta guía.
Zak
Miembro Desde 09/23/14
616 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 12-4, Blackwell Fall 2014 Miembro de USF Tampa, Team 12-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G4
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 5,459
