Saltar al contenido principal
Apple AirPort Extreme Model A1034 Antenna Replacement
Qué necesitas
  1. Apple AirPort Extreme Model A1034 Antenna Replacement, Outer Case: paso 1, imagen 1 de 1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Antenna Replacement: paso 2, imagen 1 de 1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Antenna Replacement: paso 3, imagen 1 de 2 Apple AirPort Extreme Model A1034 Antenna Replacement: paso 3, imagen 2 de 2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Antenna Replacement: paso 4, imagen 1 de 1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Antenna Replacement, Antenna: paso 5, imagen 1 de 1
    • Remove the two 4mm phillips screws to remove antenna.
  6. Apple AirPort Extreme Model A1034 Antenna Replacement: paso 6, imagen 1 de 1
    • The circuit board connected to the antenna is attached to the metal case with foam adhesive.
    • Gently peel or cut the foam holding the circuit board with a knife and remove it from the AirPort.
Conclusión
Una persona más ha completado esta guía.
Michael Garcia
Miembro Desde 10/12/11
411 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-15, Regan Fall 2011 Miembro de Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
Miembros de 3
13 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 20
Todo El Tiempo: 4,794
