Saltar al contenido principal
Apex TM772 Touchscreen Replacement
Qué necesitas
  1. Apex TM772 Touchscreen Replacement, Casing: paso 1, imagen 1 de 1
    • Begin by inserting the plastic opening tool into the seam between the back and front of the case and carefully pry the back from the front.
  2. Apex TM772 Touchscreen Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Moving along the seam continue to pry the case apart.
    • The internal speaker is adhered to the inside of the back casing. There are two wires that connect the speaker to the circuit board and may be damaged if care is not taken. Once open the speaker may be removed from the back casing by removing the tape holding the speaker with either tweezers or your fingers.
  3. Apex TM772 Touchscreen Replacement: paso 3, imagen 1 de 1
    • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
  4. Apex TM772 Touchscreen Replacement, Touchscreen: paso 4, imagen 1 de 2 Apex TM772 Touchscreen Replacement, Touchscreen: paso 4, imagen 2 de 2
    • Remove the three screws that are located at the top of the circuit board with the screwdriver. (2.4 mm head, 3.9 mm in length)
  5. Apex TM772 Touchscreen Replacement: paso 5, imagen 1 de 2 Apex TM772 Touchscreen Replacement: paso 5, imagen 2 de 2
    • Remove the touchscreen.
    • Replace the touchscreen.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 270
