Saltar al contenido principal
Apex TM772 Rear Camera Replacement
Qué necesitas
  1. Apex TM772 Rear Camera Replacement, Rear Camera: paso 1, imagen 1 de 1
    Herramienta utilizada en este paso:
    • The rear facing camera is located at the top right just below the front facing camera as looking inside the device.
    • With tweezers or your fingers remove the tape covering the camera’s pin connector.
  2. Apex TM772 Rear Camera Replacement: paso 2, imagen 1 de 1
    • With tweezers, flip the black latch to open the pin connector and remove the cable.
    • The camera is adhered to the device with double sided foam tape. Carefully remove the camera from the tape with a metal spudger. If the tape is damaged, you’ll need to replace it.
    • Replace the camera with the new one and assemble the device in reverse of these instructions.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 92
