Saltar al contenido principal
Apex Digital DTV Converter Box Power supply Board replacement
Qué necesitas
  1. Apex Digital DTV Converter Box Power supply Board replacement, Power Board: paso 1, imagen 1 de 1
    • Unplug your device from the wall outlet.
  2. Apex Digital DTV Converter Box Power supply Board replacement: paso 2, imagen 1 de 1
    • Remove the screws on the sides and rear. There are two on each side and four on the back.
    • Note: only remove the black ones (the silver ones stay for now). You should have removed eight identical screws by now.
  3. Apex Digital DTV Converter Box Power supply Board replacement: paso 3, imagen 1 de 1
    • Lift the top cover up and toward you simultaneously. It shouldn't require very much force.
  4. Apex Digital DTV Converter Box Power supply Board replacement: paso 4, imagen 1 de 1
    • Locate the power board inside the converter box.
    • Circled in red in the picture.
  5. Apex Digital DTV Converter Box Power supply Board replacement: paso 5, imagen 1 de 1
    • Remove this plug
    • You will need to squeeze the locking lever to release it. don't pull too hard.
  6. Apex Digital DTV Converter Box Power supply Board replacement: paso 6, imagen 1 de 1
    • Remove this plug from the main board. It is not detachable from the power board end.
    • Be gentle.
  7. Apex Digital DTV Converter Box Power supply Board replacement: paso 7, imagen 1 de 1
    • Remove one last cable. This one leads to the front panel
    • Be gentle.
    • Circled in red
  8. Apex Digital DTV Converter Box Power supply Board replacement: paso 8, imagen 1 de 1
    • Remove the power cord from its slot in the casing. This will make it easier to remove the power board.
    • Circled in blue
  9. Apex Digital DTV Converter Box Power supply Board replacement: paso 9, imagen 1 de 1
    • Remove the four silver colored philips screws holding the power board in.
    • Marked in pink (eeww)
  10. Apex Digital DTV Converter Box Power supply Board replacement: paso 10, imagen 1 de 1
    • Lift the power board out. Be careful to not touch the bottom of the power board. even when unplugged, it may still hold a charge.
    • Here is the empty spot.
Conclusión
6 personas más completaron esta guía.
Michel
Miembro Desde 06/18/10
288 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 9,002
