Introducción
How to open the converter box and replace the power supply...
  1. Unplug your device from the wall outlet.
    • Unplug your device from the wall outlet.
  2. Remove the screws on the sides and rear. There are two on each side and four on the back.
    • Remove the screws on the sides and rear. There are two on each side and four on the back.
    • Note: only remove the black ones (the silver ones stay for now). You should have removed eight identical screws by now.
    • Lift the top cover up and toward you simultaneously. It shouldn't require very much force.
    • Locate the power board inside the converter box.
    • Circled in red in the picture.
    • Remove this plug
    • You will need to squeeze the locking lever to release it. don't pull too hard.
    • Remove this plug from the main board. It is not detachable from the power board end.
    • Be gentle.
    • Remove one last cable. This one leads to the front panel
    • Be gentle.
    • Circled in red
    • Remove the power cord from its slot in the casing. This will make it easier to remove the power board.
    • Circled in blue
    • Remove the four silver colored philips screws holding the power board in.
    • Marked in pink (eeww)
    • Lift the power board out. Be careful to not touch the bottom of the power board. even when unplugged, it may still hold a charge.
    • Here is the empty spot.
Conclusión
5 personas más completaron esta guía.
Michel
Miembro Desde 18/06/10
261 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 7
Todo El Tiempo: 8,646
