Introducción
If you are experiencing dysfunctional buttons on the side of the brush, this guide will walk you through on how to take apart the brush in order to replace these buttons. Soldering is involved, so if you don't know how to solder take a look at this Cómo soldar y desoldar conexiones
Qué necesitas
Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
Each button is soldered in four places on the circuit board. Using the soldering tool, melt each of these four points and remove the dysfunctional buttons.
You may have to bend the dark red capacitor out of the way to reach the soldering points.
Una persona más ha completado esta guía.
