Saltar al contenido principal
Aorus X7 v2 Motherboard Replacement
Qué necesitas
  1. Aorus X7 v2 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Aorus X7 v2 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Aorus X7 v2 Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    T5 Torx Screwdriver
    $5.49
    Comprar
    • First, power off your laptop and unplug all cables and accessories. Then, place it upside down on a stable and flat surface.
    • Use the T5 Torx Screwdriver to remove the twelve screws on the bottom of the laptop. Once the screws are removed, lift off the bottom panel.
    • Use the Phillips #0 Screwdriver to remove the twelve screws holding the heatsink in place.
    • Carefully pull the two black tabs on either side of the black ribbon to disconnect them from the board.
    • Gently pull off the inner black ribbon to remove it from the board.
    • Use the Phillips #0 Screwdriver to remove the two screws holding the mSATA.
    • With a gently tug, disconnect the four white plugs.
    • Use the Phillips #0 Screwdriver to remove the two screws holding the wireless card.
  2. Aorus X7 v2 Motherboard Replacement: paso 2, imagen 1 de 3 Aorus X7 v2 Motherboard Replacement: paso 2, imagen 2 de 3 Aorus X7 v2 Motherboard Replacement: paso 2, imagen 3 de 3
    • There are three fan plugs to disconnect. In the first photo, locate and disconnect two fan plugs by gently pulling out the black wire from the white plug.
    • Locate and disconnect the third fan plug by gently pulling out the black wire from the white plug.
    • Remove blue ribbon by gently pulling.
  3. Aorus X7 v2 Motherboard Replacement: paso 3, imagen 1 de 3 Aorus X7 v2 Motherboard Replacement: paso 3, imagen 2 de 3 Aorus X7 v2 Motherboard Replacement: paso 3, imagen 3 de 3
    $5.49
    Comprar
  4. Aorus X7 v2 Motherboard Replacement: paso 4, imagen 1 de 3 Aorus X7 v2 Motherboard Replacement: paso 4, imagen 2 de 3 Aorus X7 v2 Motherboard Replacement: paso 4, imagen 3 de 3
    $5.49
    Comprar
    • Use the Phillips #0 Screwdriver to remove the three screws on the left speaker.
    • Lift the motherboard slightly near the parallel speaker screws to find the orange ribbon underneath. Use the Blunt Nose Tweezer to gently pull it off.
    • In the same area as the blue ribbon, find the orange ribbon and gently pull it off using a pair of needle nose pliers for access to remove the motherboard.
  5. Aorus X7 v2 Motherboard Replacement: paso 5, imagen 1 de 1
    • In the location of the previously removed right speaker, carefully lift off the motherboard.
Conclusión
Complete these steps in reverse order to install your new motherboard.
Una persona más ha completado esta guía.
Equipo
Gateway, Team 1-4, Pee Fall 2022 Miembro de Gateway, Team 1-4, Pee Fall 2022
GCC-PEE-F22S1G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 19
Todo El Tiempo: 492
