Introducción
Is the speaker on your answering machine not working well? This is the guide for you!
Qué necesitas
Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
Use a screwdriver to remove all four 11mm Phillips #0 screws.
Locate the speaker at the top left of the base as pictured. It is the silver, conical component. Two 7mm Phillips #0 screws hold the speaker in place.
Use a screwdriver to remove the two 7mm Phillips #0 screws.
Solder your replacement speaker into the circuit. For assistance with soldering check out the iFixit Solder and Desolder Guide.
