Saltar al contenido principal
Anne Pro 2 Keyboard Keycaps Replacement
Qué necesitas
  1. Anne Pro 2 Keyboard Keycaps Replacement, Keycaps: paso 1, imagen 1 de 1
    • Set the keyboard down on a flat surface. Make sure it is turned off and is not connected to a power source.
  2. Anne Pro 2 Keyboard Keycaps Replacement: paso 2, imagen 1 de 3 Anne Pro 2 Keyboard Keycaps Replacement: paso 2, imagen 2 de 3 Anne Pro 2 Keyboard Keycaps Replacement: paso 2, imagen 3 de 3
    • Use the keycap remover to remove the key caps from left to right.
    • Remove the smaller keycaps first so the surrounding larger caps can be removed more easily.
  3. Anne Pro 2 Keyboard Keycaps Replacement: paso 3, imagen 1 de 2 Anne Pro 2 Keyboard Keycaps Replacement: paso 3, imagen 2 de 2
    • Use the compressed air to remove all dust and hair from the keyboard.
    • Focus on the red key switches to make sure all dust and hair are removed from inside.
  4. Anne Pro 2 Keyboard Keycaps Replacement: paso 4, imagen 1 de 1
    • New replacement keycaps can be used here, but if you see no damage to older keycaps they can be re-used.
    • Use the keycap remover to set in the keycaps starting from the bottom to the top.
  5. Anne Pro 2 Keyboard Keycaps Replacement: paso 5, imagen 1 de 1
    • Inspect the final product, making sure all keycaps are back in the right place and functioning.
Linea de Meta
Una persona más ha completado esta guía.
Omar Sukkar
Miembro Desde 11/24/20
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 29
Todo El Tiempo: 1,941
