Saltar al contenido principal
Anne Pro 2 Case/Housing Replacement
Qué necesitas
  1. Anne Pro 2 Case/Housing Replacement, Case/Housing: paso 1, imagen 1 de 3 Anne Pro 2 Case/Housing Replacement, Case/Housing: paso 1, imagen 2 de 3 Anne Pro 2 Case/Housing Replacement, Case/Housing: paso 1, imagen 3 de 3
    • Unplug the Anne Pro 2 Keyboard.
    • Turn off the Anne Pro 2 Keyboard using the switch on the bottom.
  2. Anne Pro 2 Case/Housing Replacement: paso 2, imagen 1 de 2 Anne Pro 2 Case/Housing Replacement: paso 2, imagen 2 de 2
    • Using a keycap remover, remove the the following keycaps: Left Alt, Space Bar, Right Shift, Backslash, Y, H, and the Tab key.
  3. Anne Pro 2 Case/Housing Replacement: paso 3, imagen 1 de 2 Anne Pro 2 Case/Housing Replacement: paso 3, imagen 2 de 2
    • Using a Torx T5 bit, remove the five screws from the keyboard.
  4. Anne Pro 2 Case/Housing Replacement: paso 4, imagen 1 de 2 Anne Pro 2 Case/Housing Replacement: paso 4, imagen 2 de 2
    • Lift the keyboard slowly from the bottom side.
    • Do not fully lift the PCB because the battery is still plugged in.
  5. Anne Pro 2 Case/Housing Replacement: paso 5, imagen 1 de 2 Anne Pro 2 Case/Housing Replacement: paso 5, imagen 2 de 2
    • Gently unplug the battery connector by wiggling it back and forth.
  6. Anne Pro 2 Case/Housing Replacement: paso 6, imagen 1 de 2 Anne Pro 2 Case/Housing Replacement: paso 6, imagen 2 de 2
    • Remove the PCB from the main case.
    • Gently lower the PCB into the Zero-Degree housing from the top side first.
    • Firmly press it in once you have lowered it.
  7. Anne Pro 2 Case/Housing Replacement: paso 7, imagen 1 de 2 Anne Pro 2 Case/Housing Replacement: paso 7, imagen 2 de 2
    • Screw the five T5 Torx screws back into place.
  8. Anne Pro 2 Case/Housing Replacement: paso 8, imagen 1 de 2 Anne Pro 2 Case/Housing Replacement: paso 8, imagen 2 de 2
    • Take the seven keycaps you removed and gently place them in their intended spots on the keyboard.
    • Firmly press them in, ensuring they are flush with the rest of the keys.
Conclusión
2 personas más completaron esta guía.
Mohamed
Miembro Desde 09/15/20
205 Reputación
1 Guía escrita
Equipo
Un comentario
Anne Pro 2 Software manage the illumination, open the mobile App and choose a pre-programmed scheme or design your own pattern, with a distinct colour for each key if desired. The programmes are easy to use and work on both Mac and PC.
Visit Here-   https://www.techtoreview.com/top-picks/a...
Abhinav Pal - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 28
Ultimos 30 días: 136
Todo El Tiempo: 10,009
