Saltar al contenido principal
Anklet Charm Replacement
Qué necesitas
  1. Anklet Charm Replacement, Charm: paso 1, imagen 1 de 2 Anklet Charm Replacement, Charm: paso 1, imagen 2 de 2
    • To start, decide where on the chain you wish to place the charm. Thread the headpin through the chain link, and then place the charm on the headpin next to the chain.
  2. Anklet Charm Replacement: paso 2, imagen 1 de 1
    • Bend the head pin in half, with the chain and charm at the apex of the bend.
  3. Anklet Charm Replacement: paso 3, imagen 1 de 1
    • Cross the head pin to create a loop. Pull as tightly as possible.
  4. Anklet Charm Replacement: paso 4, imagen 1 de 1
    • Use round nose pliers and your hands to twist the head pin, closing off the loop. Make the twists as tight as possible. Twist 2-4 times.
  5. Anklet Charm Replacement: paso 5, imagen 1 de 1
    • Use semi-flush side cutters to cut the extra length off of the head pin.
  6. Anklet Charm Replacement: paso 6, imagen 1 de 1
    • Use round-nose pliers to fold the twisted head pin so it is flush with itself.
  7. Anklet Charm Replacement: paso 7, imagen 1 de 1
    • Finished!
Conclusión
Helene Hartfield
Miembro Desde 07/27/20
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 912
