Saltar al contenido principal
Anker Soundcore Flare Mini Waterproof Outer Shell Replacement
Qué necesitas
  1. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: paso 1, imagen 1 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: paso 1, imagen 2 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • The rubber cover of the speaker is glued down.
    • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
  2. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 2, imagen 1 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 2, imagen 2 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 2, imagen 3 de 3
    • Remove six 10 mm screws holding the plastic cover in place using a Phillips #000 screwdriver.
    • Use your hand to pull the plastic cover off the bottom of the speaker.
  3. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: paso 3, imagen 1 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: paso 3, imagen 2 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: paso 3, imagen 3 de 3
    • Remove the single 10 mm screw holding the motherboard in place using a Phillips #000 screwdriver.
    • Lift the motherboard up.
    • The motherboard is still attached to several wires underneath.
  4. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 4, imagen 1 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 4, imagen 2 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 4, imagen 3 de 3
    • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
    • When removing the power connectors, do not pull the wires themselves.
    • Remove the motherboard from the speaker.
  5. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: paso 5, imagen 1 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: paso 5, imagen 2 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: paso 5, imagen 3 de 3
    • Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
    • Remove the white plastic cover from the speaker.
  6. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 6, imagen 1 de 2 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 6, imagen 2 de 2
    • Remove the other four 11 mm screws holding the outer shell in place with a Phillips #1 screwdriver.
  7. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 7, imagen 1 de 1
    • Pull the charging port away from the side of the speaker.
  8. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 8, imagen 1 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 8, imagen 2 de 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: paso 8, imagen 3 de 3
    • Use a spudger to loosen the cover from the inner components of the speaker.
    • Slide the cover completely off.
    • One wire will still be connected to the shell.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Where can I purchase the outer shell? Share link please
Arsam Sohail - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 416
