Saltar al contenido principal
Anker Soundcore Flare Mini Motherboard Replacement
Qué necesitas
  1. Anker Soundcore Flare Mini Motherboard Replacement, Bottom Cover: paso 1, imagen 1 de 3 Anker Soundcore Flare Mini Motherboard Replacement, Bottom Cover: paso 1, imagen 2 de 3 Anker Soundcore Flare Mini Motherboard Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • The rubber cover of the speaker is glued down.
    • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
  2. Anker Soundcore Flare Mini Motherboard Replacement: paso 2, imagen 1 de 3 Anker Soundcore Flare Mini Motherboard Replacement: paso 2, imagen 2 de 3 Anker Soundcore Flare Mini Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove six 10 mm screws holding the plastic cover in place using a Phillips #000 screwdriver.
    • Use your hand to pull the plastic cover off the bottom of the speaker.
  3. Anker Soundcore Flare Mini Motherboard Replacement, Motherboard: paso 3, imagen 1 de 3 Anker Soundcore Flare Mini Motherboard Replacement, Motherboard: paso 3, imagen 2 de 3 Anker Soundcore Flare Mini Motherboard Replacement, Motherboard: paso 3, imagen 3 de 3
    • Remove the single 10 mm screw holding the motherboard in place using a Phillips #000 screwdriver.
    • Lift the motherboard up.
    • The motherboard is still attached to several wires underneath.
  4. Anker Soundcore Flare Mini Motherboard Replacement: paso 4, imagen 1 de 3 Anker Soundcore Flare Mini Motherboard Replacement: paso 4, imagen 2 de 3 Anker Soundcore Flare Mini Motherboard Replacement: paso 4, imagen 3 de 3
    • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
    • When removing the power connectors, do not pull the wires themselves.
    • Remove the motherboard from the speaker.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 44
Todo El Tiempo: 876
