Saltar al contenido principal
Introducción
In order to replace any component of the Anker Soundcore Flare Mini speaker, the rubber and plastic cover on the bottom of the speaker needs to be removed.
These parts protect the internal and electrical components of the speaker from the elements such as water and dirt. It also prevents internal damage or the loss of loose parts.
Before starting the replacement, make sure the speaker is turned off and is unplugged from the power cord!
Partes
No se especificaron partes.
  1. Anker Soundcore Flare Mini Bottom Cover Replacement, Bottom Cover: paso 1, imagen 1 de 3 Anker Soundcore Flare Mini Bottom Cover Replacement, Bottom Cover: paso 1, imagen 2 de 3 Anker Soundcore Flare Mini Bottom Cover Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • The rubber cover of the speaker is glued down.
    • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
  2. Anker Soundcore Flare Mini Bottom Cover Replacement: paso 2, imagen 1 de 3 Anker Soundcore Flare Mini Bottom Cover Replacement: paso 2, imagen 2 de 3 Anker Soundcore Flare Mini Bottom Cover Replacement: paso 2, imagen 3 de 3
    • Remove six 10 mm screws holding the plastic cover in place using a Phillips #000 screwdriver.
    • Use your hand to pull the plastic cover off the bottom of the speaker.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 110
