Saltar al contenido principal
Anker SoundCore 2 Motherboard Replacement
Qué necesitas
  1. Anker SoundCore 2 Motherboard Replacement, Front Panel: paso 1, imagen 1 de 2 Anker SoundCore 2 Motherboard Replacement, Front Panel: paso 1, imagen 2 de 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Motherboard Replacement, Motherboard: paso 2, imagen 1 de 3 Anker SoundCore 2 Motherboard Replacement, Motherboard: paso 2, imagen 2 de 3 Anker SoundCore 2 Motherboard Replacement, Motherboard: paso 2, imagen 3 de 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Motherboard Replacement: paso 3, imagen 1 de 3 Anker SoundCore 2 Motherboard Replacement: paso 3, imagen 2 de 3 Anker SoundCore 2 Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
Conclusión
Kristen Gismondi
Miembro Desde 11/12/14
77,552 Reputación
184 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
142 Miembros
16,238 Guías creadas
3 comentarios
Where can I buy the C34 and ESD4?
Abel Omeokwe - Contestar
Hello.
Do you know where to fond an Anker motherboard please?
Thanks
ckridene - Contestar
Princelee Balasingham Prince - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 50
Todo El Tiempo: 1,105
