Saltar al contenido principal
Anker SoundCore 2 Charging Port Replacement
Qué necesitas
  1. Anker SoundCore 2 Charging Port Replacement, Front Panel: paso 1, imagen 1 de 2 Anker SoundCore 2 Charging Port Replacement, Front Panel: paso 1, imagen 2 de 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Charging Port Replacement, Motherboard: paso 2, imagen 1 de 3 Anker SoundCore 2 Charging Port Replacement, Motherboard: paso 2, imagen 2 de 3 Anker SoundCore 2 Charging Port Replacement, Motherboard: paso 2, imagen 3 de 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Charging Port Replacement: paso 3, imagen 1 de 3 Anker SoundCore 2 Charging Port Replacement: paso 3, imagen 2 de 3 Anker SoundCore 2 Charging Port Replacement: paso 3, imagen 3 de 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
  4. Anker SoundCore 2 Charging Port Replacement, Charging Port: paso 4, imagen 1 de 2 Anker SoundCore 2 Charging Port Replacement, Charging Port: paso 4, imagen 2 de 2
    • Desolder the charging port from the motherboard and solder a new one on.
    • For help with soldering and desoldering, follow this guide.
Conclusión
5 personas más completaron esta guía.
5 comentarios
Hello please what's the model of the ESD4 and C34 close to the charging port?
Abel Omeokwe - Contestar
Where can i get a replacement charging Port?
A K - Contestar
what's the micro usb port part number? I want to replace it but can't find info on it anywhere.
Tomasz Konwalski - Contestar
I've made the replacement, but with a spare type c port and...it's not working. Can someone help?
Delyan - Contestar
I use Anker OEM style replacement in my repair shop from eBay listing 254057783007
Perfect fit.
https://www.ebay.com/itm/254057783007
Good luck with the project
G.K. - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 24
Ultimos 30 días: 88
Todo El Tiempo: 2,890
