Saltar al contenido principal
Este teardown está en en curso – Recarga periódicamente para ver los cambios más recientes!
Qué necesitas
  1. Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: paso 1, imagen 1 de 3 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: paso 1, imagen 2 de 3 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: paso 1, imagen 3 de 3
    • Unscrew the battery cap
    • Remove battery
    • The cap is heavily tightened from the factory, therefore it may be necessary to use a rubber mat for added grip.
  2. Anker LC-90 Rechargeable Flashlight Teardown: paso 2, imagen 1 de 1
    • Unscrew the lens holder as shown in the picture
  3. Anker LC-90 Rechargeable Flashlight Teardown: paso 3, imagen 1 de 3 Anker LC-90 Rechargeable Flashlight Teardown: paso 3, imagen 2 de 3 Anker LC-90 Rechargeable Flashlight Teardown: paso 3, imagen 3 de 3
    • Slide the lens housing down, toward the base, to remove
    • Note that once the lens housing is pushed down the lens and reflector pop out.
  4. Anker LC-90 Rechargeable Flashlight Teardown: paso 4, imagen 1 de 1
    • The Anker LC-90 is now tore down
Nick Wolfe
Miembro Desde 01/24/18
709 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S18-G4, Livingston Winter 2018 Miembro de Cal Poly, Team S18-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G4
4 Miembros
13 Guías creadas
5 comentarios
cannot buy parts or return
JULIA - Contestar
have an l90 by anker
where can i get parts
seems to need new assembly where u plug in usb
JULIA - Contestar
Have 3 LC90 flashlight with the same problems, switch stuck & intermittently works! Need 3 replacement cap/switches part #??
Ray Miller - Contestar
Where can I find a replacement bulb assembly for an anker bolder flashlight?
richard pare sr - Contestar
Thanks for the information. Took the flashlight battery out and then put in back in; seems to be working great for now!
Steve Moss - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 19
Ultimos 30 días: 54
Todo El Tiempo: 3,850
