Introducción
This manual shows how to simply replace the sensor on the Anker 2.4G wireless mouse. Before moving on with the first step, check the battery casing for any corrosion or visible damage. Beware, this guide requires use of a soldering iron which needs to be handled with caution. The instructions on how to solder can be found here Cómo soldar y desoldar conexiones.
Qué necesitas
Using a spudger, carefully pry off the stickers to reveal the location of four screws.
2 personas más completaron esta guía.
