Introducción
This mouse was designed with usability in mind taking little to no effort to fix anything.
  1. Use the screwdriver to remove the stickers hiding the screws marked in red.
    • Use the screwdriver to remove the stickers hiding the screws marked in red.
  2. Remove the 4 screws to continue.
    • Remove the 4 screws to continue.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Pry the center of the mouse apart to separate the upper and lower housing of the boards. Pry the center of the mouse apart to separate the upper and lower housing of the boards.
    • Pry the center of the mouse apart to separate the upper and lower housing of the boards.
  5. Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Don't pull the wires too hard, as they might break.
  6. Pull the Scroll wheel, in red, to the left to remove it. This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
    • Pull the Scroll wheel, in red, to the left to remove it.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
    • Replace/clean if needed.
    • If your mouse still doesn't work after this step, please continue onto the next step.
  7. Desolder these 3 pins and solder the replacement part in.
    • Desolder these 3 pins and solder the replacement part in.
Conclusión
Vincent Lee
Miembro Desde 23/01/14
361 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-39, Maness Winter 2014 Miembro de Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Miembros
8 Guías creadas
Hi Vincent, could you please help me with finding a place where this rotation sensor can be bought. I'm not even sure how this part is called so searching for it is quite tricky.
Cheers,
Michal
Michal Rorat - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 11
Últimos 30 Días: 91
Todo El Tiempo: 4,642
