Saltar al contenido principal
Anker 2.4G Wireless Mouse LED Replacement
Qué necesitas
  1. Anker 2.4G Wireless Mouse LED Replacement, LED: paso 1, imagen 1 de 1
    • Use a spudger to gently pry off the stickers to reveal the location of the four screws.
  2. Anker 2.4G Wireless Mouse LED Replacement: paso 2, imagen 1 de 1
    • Remove the four screws to continue.
  3. Anker 2.4G Wireless Mouse LED Replacement: paso 3, imagen 1 de 2 Anker 2.4G Wireless Mouse LED Replacement: paso 3, imagen 2 de 2
    • Pry the center of the mouse apart using a spudger to separate the upper and lower housing of the boards.
  4. Anker 2.4G Wireless Mouse LED Replacement: paso 4, imagen 1 de 1
    • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse LED Replacement: paso 5, imagen 1 de 2 Anker 2.4G Wireless Mouse LED Replacement: paso 5, imagen 2 de 2
    • Take the upper housing of the mouse and remove the two screws that hold the board in place.
  6. Anker 2.4G Wireless Mouse LED Replacement: paso 6, imagen 1 de 1
    • Gently remove the circuit board from the mouse.
  7. Anker 2.4G Wireless Mouse LED Replacement: paso 7, imagen 1 de 1
    • To remove the LED, flip the board over and desolder the wires.
    • Replace LED with a new LED and resolder into place.
Conclusión
Colin
Miembro Desde 02/10/14
406 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 1-39, Maness Winter 2014 Miembro de Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 2,913
