Introducción
Using this guide will help you to successfully replace a faulty speaker on your tablet. Tablet needs to be disassembled first, then speaker has to be soldered in place. Follow steps 1-3 to open the device. Ignore steps 4 and 5 and go straight to step 6 after doing so.
Qué necesitas
Remove the two 00 Phillips screws located in the right hand side of the tablet.
The speaker is located on the top left hand side of the tablet.
Remove the electrical tape covering the connections to expose the wires.
To reassemble your device, follow these instructions in reverse order. Do not forget to put electrical tape back in place.
2 personas más completaron esta guía.
