Saltar al contenido principal
Android tablet Nobis NB09 Camera Replacement
Qué necesitas
  1. Android tablet Nobis NB09 Camera Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the two 00 Phillips screws located in the right hand side of the tablet.
  2. Android tablet Nobis NB09 Camera Replacement: paso 2, imagen 1 de 3 Android tablet Nobis NB09 Camera Replacement: paso 2, imagen 2 de 3 Android tablet Nobis NB09 Camera Replacement: paso 2, imagen 3 de 3
    • Use plastic opening tools to loosen and pry off the back plate (pink piece).
    • When removing the cover, be careful not to pull too hard as there are wires connected to the motherboard attached to the back cover.
  3. Android tablet Nobis NB09 Camera Replacement, Camera: paso 3, imagen 1 de 2 Android tablet Nobis NB09 Camera Replacement, Camera: paso 3, imagen 2 de 2
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Start by removing the electrical tape covering the camera, located at the top left corner of the device.
    • Remove enough tape to expose the ZIF connector and the camera.
  4. Android tablet Nobis NB09 Camera Replacement: paso 4, imagen 1 de 1
    • Lift up the black plastic lock on the ZIF connector with tweezers.
    • ZIF stands for Zero Insertion Force connector. Make sure the connector is unlocked completely.
  5. Android tablet Nobis NB09 Camera Replacement: paso 5, imagen 1 de 2 Android tablet Nobis NB09 Camera Replacement: paso 5, imagen 2 de 2
    • Gently remove the camera by removing the power cord with tweezers. The camera should release easily: do not twist or pull too hard.
    • Replace the camera with a new one.
Conclusión
To reassemble your device, follow these instructions in reverse order. Do not forget to put electrical tape back in place.
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team 7-1, Cichon Spring 2015 Miembro de UMass Dartmouth, Team 7-1, Cichon Spring 2015
UMASSD-CICHON-S15S7G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 146
