Saltar al contenido principal
Andoer HDV 107 Strap Replacement
Qué necesitas
  1. Andoer HDV 107 Strap Replacement, Strap: paso 1, imagen 1 de 1
    • At the bottom of the camera you will see the battery compartment cover as seen in the picture
    • To open this compartment, apply pressure in the direction of the arrow and remove.
  2. Andoer HDV 107 Strap Replacement: paso 2, imagen 1 de 1
    • Remove the 1 mm circled screws with the Phillips head #000 screwdriver.
  3. Andoer HDV 107 Strap Replacement: paso 3, imagen 1 de 1
    • Remove the 1 mm Phillips head screw.
  4. Andoer HDV 107 Strap Replacement: paso 4, imagen 1 de 1
    • Once all previous screws have been removed the panel can be pulled off of the camera.
  5. Andoer HDV 107 Strap Replacement: paso 5, imagen 1 de 1
    • Use your screwdriver to remove the 1 mm Phillips head screw and release the strap.
Conclusión
Isaac Saron
Miembro Desde 03/20/17
516 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 150
