Saltar al contenido principal
Andoer HDV 107 Battery Replacement
  1. Andoer HDV 107 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • At the bottom of the camera you will see the battery compartment cover as seen in the picture.
    • To open this compartment, apply pressure in the direction of the arrow and remove.
  2. Andoer HDV 107 Battery Replacement: paso 2, imagen 1 de 1
    • You will see the battery being held in place by a clear plastic kickstand.
    • Use your finger to move the kickstand away from the battery.
  3. Andoer HDV 107 Battery Replacement: paso 3, imagen 1 de 1
    • With your other hand press down on the battery slightly and remove the battery.
    • If the battery does not come out right away try to line the battery up with the sides to give it a clear path out of the compartment.
Conclusión
Isaac Saron
Miembro Desde 03/20/17
516 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 348
