Saltar al contenido principal
Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement
Qué necesitas
  1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: paso 1, imagen 1 de 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: paso 1, imagen 2 de 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: paso 1, imagen 3 de 3
    • Complete this step to reduce the risk of burns, fire, electric shock, or injury.
    • Turn the control on the trimmers to "off".
    • Remove the plug from the electrical outlet.
  2. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: paso 2, imagen 1 de 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: paso 2, imagen 2 de 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: paso 2, imagen 3 de 3
    • Remove the two blade screws from the top blade of the trimmer.
  3. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: paso 3, imagen 1 de 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: paso 3, imagen 2 de 2
    • Lift the top blade from the device.
    • The bottom blade is attached, but not secured, to the underside of the top blade.
  4. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: paso 4, imagen 1 de 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: paso 4, imagen 2 de 2
    • Flip the top blade over.
    • Lift the bottom blade from the top blade.
  5. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: paso 5, imagen 1 de 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: paso 5, imagen 2 de 2
    • Clean or lubricate the device if necessary.
Conclusión
2 personas más completaron esta guía.
David Taylor
Miembro Desde 10/08/14
151 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-34, Donnelly Fall 2014 Miembro de USF Tampa, Team 1-34, Donnelly Fall 2014
USFT-DONNELLY-F14S1G34
1 Miembro
1 Guía escrita
Un comentario
Trying to find out how to sharpen. Blades are so expensive. $ 24 per pack.
I cut my hair every two weeks. Then dull blades.
I'd invest in some type of sharpening tool. ( Not sand paper ).
rslau13@gmail.com
Map daddy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 68
Todo El Tiempo: 6,720
