Saltar al contenido principal
American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement
Qué necesitas
  1. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the sandpaper disc: paso 1, imagen 1 de 1
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement: paso 2, imagen 1 de 1
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the driver pad: paso 3, imagen 1 de 2 American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the driver pad: paso 3, imagen 2 de 2
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
Conclusión
2 personas más completaron esta guía.
Adam O'Camb
Miembro Desde 04/11/15
177,356 Reputación
418 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 75
Todo El Tiempo: 2,439
