Saltar al contenido principal
Ambient Weather WS-1001-Wifi LCD Screen Replacement
Qué necesitas
  1. Ambient Weather WS-1001-Wifi LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • First, you will need to remove all four M2x1-7 screws (7mm length) located on the back of the device. This should be done using a Phillips #1 screw driver.
  2. Ambient Weather WS-1001-Wifi LCD Screen Replacement: paso 2, imagen 1 de 1
    • From the side of the device use the plastic opening tool to pry the gray front casing from the rear black casing.
    • The ribbon cable is attached inside so the two pieces will not come completely apart. See step 3.
  3. Ambient Weather WS-1001-Wifi LCD Screen Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, carefully press the black bar towards the ribbon and away from the white bar in order to release it.
    • The ribbon cable should come out and be attached to the back of the LCD screen resulting in two separate pieces.
  4. Ambient Weather WS-1001-Wifi LCD Screen Replacement: paso 4, imagen 1 de 2 Ambient Weather WS-1001-Wifi LCD Screen Replacement: paso 4, imagen 2 de 2
    • Next, you need to remove the LCD screen from the front casing.
    • Push on the front of the LCD screen to pop it out as seen in picture 2.
Conclusión
Jeremiah Miskimen
Miembro Desde 11/06/17
107 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G2, Harley Fall 2017 Miembro de IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 Miembros
3 Guías creadas
2 comentarios
Pretty useless guide since this is all pretty self explanatory with no reference on where to get a replacement or even a part number
Jared Dykstra - Contestar
Exactly right.
j drag -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 364
