Introducción
In this fix we will be looking at how to replace the internal battery used to store electrical charge for the device. This will require a Phillips #1 screwdriver, a small plastic tool to remove the LCD screen and to remove the battery.
Good Luck!
Qué necesitas
First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
Pry the front silver panel away from the back black panel with a plastic opening tool.
Una persona más ha completado esta guía.
