Saltar al contenido principal
Ambient Weather WS-1001-Wifi Battery Replacement
Qué necesitas
  1. Ambient Weather WS-1001-Wifi Battery Replacement, Battery: paso 1, imagen 1 de 2 Ambient Weather WS-1001-Wifi Battery Replacement, Battery: paso 1, imagen 2 de 2
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. Ambient Weather WS-1001-Wifi Battery Replacement: paso 2, imagen 1 de 1
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Ambient Weather WS-1001-Wifi Battery Replacement: paso 3, imagen 1 de 2 Ambient Weather WS-1001-Wifi Battery Replacement: paso 3, imagen 2 de 2
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. Ambient Weather WS-1001-Wifi Battery Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • The battery can then be popped out using precision tweezers and replaced with a new one.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team S1-G2, Harley Fall 2017 Miembro de IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 Miembros
3 Guías creadas
Un comentario
Hello. My screen is not working. And the electric cable is good.
C Kaagman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 783
