Saltar al contenido principal
AmazonBasics BTV1 Motherboard Replacement
Qué necesitas
  1. AmazonBasics BTV1 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 AmazonBasics BTV1 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Motherboard Replacement: paso 2, imagen 1 de 2 AmazonBasics BTV1 Motherboard Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Motherboard Replacement: paso 3, imagen 1 de 2 AmazonBasics BTV1 Motherboard Replacement: paso 3, imagen 2 de 2
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Motherboard Replacement: paso 4, imagen 1 de 2 AmazonBasics BTV1 Motherboard Replacement: paso 4, imagen 2 de 2
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
  5. AmazonBasics BTV1 Motherboard Replacement: paso 5, imagen 1 de 1
    • Gently pull out the two ribbon connectors to disconnect the motherboard from the case.
Conclusión
2 personas más completaron esta guía.
Chris Shannon
Miembro Desde 02/01/16
1,039 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 14-2, Lacy Spring 2016 Miembro de USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 492
