Saltar al contenido principal
AmazonBasics B00Q3KFX8U Drive Gear Replacement
Qué necesitas
  1. AmazonBasics B00Q3KFX8U Drive Gear Replacement, Drive Gear: paso 1, imagen 1 de 1
    • Remove the shredder assembly from the paper scrap bin.
  2. AmazonBasics B00Q3KFX8U Drive Gear Replacement: paso 2, imagen 1 de 1
    • Remove the two 10mm PH1 screws holding the small black panel in place.
  3. AmazonBasics B00Q3KFX8U Drive Gear Replacement: paso 3, imagen 1 de 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: paso 3, imagen 2 de 2
    • Remove the six 14mm PH1 screws holding the bottom cover in place.
    • Remove the cover by lifting straight upwards.
    • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
  4. AmazonBasics B00Q3KFX8U Drive Gear Replacement: paso 4, imagen 1 de 1
    • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
    • The blades are sharp. Coming into contact with them may result in injury.
  5. AmazonBasics B00Q3KFX8U Drive Gear Replacement: paso 5, imagen 1 de 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: paso 5, imagen 2 de 2
    • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
  6. AmazonBasics B00Q3KFX8U Drive Gear Replacement: paso 6, imagen 1 de 1
    • Use a metal spudger to pry the bracket from the main shredder assembly.
    • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
  7. AmazonBasics B00Q3KFX8U Drive Gear Replacement: paso 7, imagen 1 de 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: paso 7, imagen 2 de 2
    • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
Conclusión
William Foley
Miembro Desde 03/25/16
548 Reputación
4 Guías creadas
Equipo
Un comentario
Where does one buy these gear parts?
opticdreams - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,190
