Saltar al contenido principal
AmazonBasics B0050BPWBQ On/Off Switch Replacement
Qué necesitas
  1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: paso 1, imagen 1 de 2 AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: paso 1, imagen 2 de 2
    • The unit head needs to be switched to the off position and unplugged before any disassembly.
    • When removing screws in the following steps, make sure the unit is resting on a flat surface because pieces will easily come apart.
    • Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
  2. AmazonBasics B0050BPWBQ On/Off Switch Replacement: paso 2, imagen 1 de 2 AmazonBasics B0050BPWBQ On/Off Switch Replacement: paso 2, imagen 2 de 2
    • Upon removal of the next screws, the front panel and the shredding component attached to it will fall apart from the back panel so have the unit resting on a flat surface.
    • Remove two 50 mm Phillips #1 screws from the middle of the underside of the head unit.
  3. AmazonBasics B0050BPWBQ On/Off Switch Replacement: paso 3, imagen 1 de 1
    • Lay the back panel away from the front panel on a flat surface.
    • The back panel will be light because it is only the plastic, while the front panel will be heavy with the shredding component attached to it.
  4. AmazonBasics B0050BPWBQ On/Off Switch Replacement: paso 4, imagen 1 de 2 AmazonBasics B0050BPWBQ On/Off Switch Replacement: paso 4, imagen 2 de 2
    • Find the green control board that is located next to the shredding motor.
    • Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
    • You may need to move wires over to find the screws.
  5. AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: paso 5, imagen 1 de 3 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: paso 5, imagen 2 de 3 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: paso 5, imagen 3 de 3
    • Pull the front panel away from the shredding unit.
    • Locate the black On/Off switch attached to the front panel where the control board was once attached.
    • Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
Conclusión
Una persona más ha completado esta guía.
Natalie Meert
Miembro Desde 02/11/16
678 Reputación
4 Guías creadas
Equipo
IUPUI, Team 2-4, Baechle Spring 2016 Miembro de IUPUI, Team 2-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G4
4 Miembros
8 Guías creadas
Un comentario
Does anyone know where to buy a replacement switch?
Shawn - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 2,336
