Saltar al contenido principal
Amazon Tap Battery Replacement
Qué necesitas
  1. Amazon Tap Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Use the metal spudger to remove the rubber control panel at the top end of the speaker.
  2. Amazon Tap Battery Replacement: paso 2, imagen 1 de 2 Amazon Tap Battery Replacement: paso 2, imagen 2 de 2
    • Turning the speaker to the bottom end, peel back the Tap's rubber footing.
    • Use a T6 screwdriver to remove the the Tap's base.
  3. Amazon Tap Battery Replacement: paso 3, imagen 1 de 2 Amazon Tap Battery Replacement: paso 3, imagen 2 de 2
    • Time to break through the Tap's exterior. The only way to disassemble the Tap is from the outside.
    • First, remove the Tap's stretchy fabric wrap. Unroll the stretchy fabric from the sticky cowling.
    • After removing the stretchy fabric completely, the adhesive cowling remains.
  4. Amazon Tap Battery Replacement: paso 4, imagen 1 de 1
    • Next up: removing the cowling.
    • This step requires many pry tools, and even more patience.
    • The key to remove the cowling is to slide it over the microphone, Bluetooth, and power buttons.
    • Once the cowling is off, only a few screws remain until the interior is reached. Progress!
  5. Amazon Tap Battery Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to remove the speaker button while using another pair of tweezers to hold the button steady.
    • Since the button is round, it is best to hold it steady and wiggle it in a slow motion until it comes loose.
  6. Amazon Tap Battery Replacement: paso 6, imagen 1 de 2 Amazon Tap Battery Replacement: paso 6, imagen 2 de 2
    • Once you remove the buttons its safe to pull apart the Amazon Tap.
    • Here you will find a standard 18650 Lithium Ion cell battery.
    • Carefully remove the Lithium Ion Cell Battery and insert a new one.
Conclusión
To reassemble the Amazon Tap device, follow these instructions in reverse order.
9 personas más completaron esta guía.
11 comentarios
Wow! Thanks for demystifying this!
ErrOr CReePeR - Contestar
Thank you for the guide as it is very helpful! Here is a replacement battery for the Amazon Tap:
Amazon Tap Replacement Battery
It even comes with the necessary tools to complete the repair.
michaelf33707 - Contestar
Excellent.
made this very easy for me
cyber_jack99 - Contestar
Where does this leave us?? All taken apart and repaired, but with no way to purchase parts to replace the ones ripped apart during removal, nor the skills to put them on looking attractive with near the skills of the Chinese who probably build one of these things every 1.457 minutes at the factory!
Steve Dorff - Contestar
Thank you. I was able to replace the battery. Your step by step guide was excellent. Though I could not fix the tip panel correctly I can operate its functions hands free. If show me how to fix top panel I WILL be appreciate
Gopaal goor68 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 25
Ultimos 30 días: 157
Todo El Tiempo: 11,414
