Saltar al contenido principal
Introducción
We took apart the Kindle Paperwhite 3 (7th Generation) to find a simple constructions. The Paperwhite 3 comprises a e-ink screen, replaceable battery, and a single motherboard, earning it a respectable 8 out of 10 for repairability.
  1. Amazon Kindle Paperwhite 7th Generation Repairability Assessment, Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 1, imagen 1 de 3 Amazon Kindle Paperwhite 7th Generation Repairability Assessment, Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 1, imagen 2 de 3 Amazon Kindle Paperwhite 7th Generation Repairability Assessment, Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 1, imagen 3 de 3
    • Front and rear reference shot.
  2. Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 2, imagen 1 de 2 Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 2, imagen 2 de 2
    • Adhesive is holding the bezel in place.
    • An opening pick and an iFixit opening tool were the only tools needed to remove the bezel.
    • No heat was needed, yielding a moderately difficult opening procedure.
  3. Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 3, imagen 1 de 3 Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 3, imagen 2 de 3 Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 3, imagen 3 de 3
    • There are 11 Phillips screws holding the midframe to the rear case. One of those screws is hidden underneath tape.
    • Once the screws are out the midframe easily separates from the rear case.
    • The battery and motherboard are connected to the rear case.
  4. Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 4, imagen 1 de 3 Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 4, imagen 2 de 3 Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 4, imagen 3 de 3
    • Battery is held in place by three Phillips screws.
    • Once the screws are removed, the battery can be removed by lifting from the bottom.
  5. Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 5, imagen 1 de 2 Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 5, imagen 2 de 2
    • The motherboard is held in by 5 Phillips screws.
    • There are 3 ZIF connectors and 1 press connector that must be disconnected before removing the motherboard.
  6. Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 6, imagen 1 de 2 Amazon Kindle Paperwhite 7th Generation Repairability Assessment: paso 6, imagen 2 de 2
    • The Amazon Kindle Paperwhite earns an 8 out of 10 on our repairability scale (10 is the easiest to repair):
    • The battery was very easy to remove.
    • All screws were Phillips #00 screws.
    • All components likely needing replacement were modular, except for the USB port.
    • Thin layer of adhesive that needed to broken in order to remove the bezel and access the internal components.
    • Manufacturer does not provide user-accessible repair documentation.
Linea de Meta
14 personas más completaron esta guía.
Evan Noronha
Miembro Desde 05/02/15
216,074 Reputación
177 Guías creadas
Equipo
The Home Depot Miembro de The Home Depot
Community
10,059 Miembros
1,027 Guías creadas
2 comentarios
Thanks! Looking to replace scratched screen and this gives me confidence to diy.
Ricardo Birnbaum - Contestar
Hi! How should I replace or fix the USB port? It’s malfunctioning and making my Kindle charge intermittently.
Uriel Tapia - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 33
Ultimos 30 días: 153
Todo El Tiempo: 8,699
