Introducción
As your Kindle gets older the battery life for it gets worse. This guide will teach you how to replace the battery for your Kindle, so you can enjoy hours of reading without having to charge it as often.
Qué necesitas
Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
Attach the new battery by inserting the end of the orange power connector (the end not attached to the battery) clips into a little socket on the device (it's barely visible). You can tell when it clips in by the feel and sound. Make sure that when you put the new battery in, you first clip the connector in before you stick the tape down.
Be Aware: Your new battery might not be charged, so it may not power-on immediately! After replacing the battery, plug your Oasis in and let the battery charge to full capacity.
18 personas más completaron esta guía.
23 comentarios
Grate explanation. where can I find the battery? couldn’t find it anywhere
thanks
Hi, same comment: great and interesting but I can’t find the battery anywhere…
You can find the battery here
https://www.nextbatteries.com/products/a...
890 mAH Li-Polymer 3.7V 61.60 x 53.32 x 2.78mm
