Introducción
Disassembly of the Amazon Fire Tablet 5th Generation revealed a simple design with a LCD display, motherboard, battery, and unfused digitizer. The digitizer and battery adhesives needed some elbow grease to break through, but overall we were happy to award this design a 7 out of 10 for repairability.
Front and back reference shots.
  • Front and back reference shots.
Agregar Comentario
There are only clips holding the assembly together. No adhesive makes for much easier device access.
  • There are only clips holding the assembly together. No adhesive makes for much easier device access.
  • The plastic back cover comes off to reveal the battery, motherboard, and display hiding on the other side.
  • We can also see smaller components, including a speaker and a camera.
Agregar Comentario
  • This battery isn't super easy to remove. It's held in with several adhesive strips that require force to separate.
  • We use a card to fight the adhesive and we can pry the battery out with a bit of effort.
  • At the top of the motherboard there's a little tamper evident sticker.
Agregar Comentario
  • We can remove the motherboard after removing five Phillips screws, and disconnecting two ZIF and two press connectors.
  • Front-facing camera is modular and easily pops out.
  • Rear-facing camera is soldered to the board and not going anywhere.
Agregar Comentario
  • Just the display assembly's left. How hard is a digitizer replacement?
    • Hard.
Agregar Comentario
  • The Amazon Fire Tablet earns a 7 out of 10 on our repairability scale (10 is the easiest to repair):
    • The plastic case assembly is held together by clips and no adhesive, and opening only requires prying with an iFixit opening tool.
    • The digitizer and LCD panel are not fused together.
    • All of the screws in the device are Phillips screws.
    • The battery is modular, but it is held in place by somewhat stubborn adhesive.
    • Removing the digitizer and LCD panel requires fighting through some very resilient adhesive.
    • Manufacturer does not provide user-accessible repair documentation.
Agregar Comentario
Linea de Meta
3 personas más completaron esta guía.
Scott Havard
Miembro Desde 27/06/16
22,508 Reputación
131 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 35
Últimos 30 Días: 138
Todo El Tiempo: 2,052
