Saltar al contenido principal
Amazon Fire TV Stick Remote Battery Replacement
Qué necesitas
  1. Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: paso 1, imagen 1 de 3 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: paso 1, imagen 2 de 3 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: paso 1, imagen 3 de 3
    • Use the plastic opening tool to press into the seam between the remote and battery cover.
    • With the same tool to help pop the batteries out.
  2. Amazon Fire TV Stick Remote Battery Replacement: paso 2, imagen 1 de 1
    • Place two fresh batteries back inside the remote and slide the cover back on.
    • Ensure positive ends of the batteries both point towards the top of the remote.
Conclusión
7 personas más completaron esta guía.
Andrew Busse
Miembro Desde 07/12/16
870 Reputación
2 Guías creadas
Equipo
IUPUI, Team 2-3, Harley SU 2016 Miembro de IUPUI, Team 2-3, Harley SU 2016
IUPUI-HARLEY-SU16S2G3
4 Miembros
13 Guías creadas
35 comentarios
do you have to use amazon batteries...my remote doesn't work with duracell
mtimken - Contestar
Hey @mtimken ! As far we know, there isnt anything special about Amazon's AAA batteries. Any two *new* AAA batteries should work just fine. Are you certain both of your Duracell batteries are new? Are they rechargeable batteries that need to be charged up fully? Let us know what you find out! Good luck.
Kelsea Weber -
That's my question what type of batteries do I need for my Amazon Fire stick
biba.anderson41 - Contestar
The remote takes two AAA batteries. See the answer to the comment above. In the future, go ahead and post your question in the Answers forum : ifixit.com/answers. You may get an answer faster by posting where all of our community members can see your question. I hope this helps. Happy fixing!
Kelsea Weber -
Hello having problem with firestick Remote cant get it to work ? i change batteries still not working?
denise carter - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 47
Ultimos 30 días: 220
Todo El Tiempo: 116,540
