Saltar al contenido principal
Amazon Fire TV Power Cord Port Replacement
Qué necesitas
  1. Amazon Fire TV Power Cord Port Replacement, Motherboard: paso 1, imagen 1 de 3 Amazon Fire TV Power Cord Port Replacement, Motherboard: paso 1, imagen 2 de 3 Amazon Fire TV Power Cord Port Replacement, Motherboard: paso 1, imagen 3 de 3
    • Place the plastic opening tool in the space between the rubber and the plastic case of the device.
    • Apply pressure by pushing upward on the case.
    • Separate the bottom square rubber piece from the case using the plastic opening tool until all clips are detached.
  2. Amazon Fire TV Power Cord Port Replacement: paso 2, imagen 1 de 2 Amazon Fire TV Power Cord Port Replacement: paso 2, imagen 2 de 2
    • Locate the ten J#00 Phillips screws and remove them.
  3. Amazon Fire TV Power Cord Port Replacement: paso 3, imagen 1 de 3 Amazon Fire TV Power Cord Port Replacement: paso 3, imagen 2 de 3 Amazon Fire TV Power Cord Port Replacement: paso 3, imagen 3 de 3
    • Place your finger on the short edge of the motherboard and lift it to separate it from the plastic case.
  4. Amazon Fire TV Power Cord Port Replacement, Power Cord Port: paso 4, imagen 1 de 3 Amazon Fire TV Power Cord Port Replacement, Power Cord Port: paso 4, imagen 2 de 3 Amazon Fire TV Power Cord Port Replacement, Power Cord Port: paso 4, imagen 3 de 3
    • With the mother board back facing you locate the power cord port found on the far left end.
  5. Amazon Fire TV Power Cord Port Replacement: paso 5, imagen 1 de 3 Amazon Fire TV Power Cord Port Replacement: paso 5, imagen 2 de 3 Amazon Fire TV Power Cord Port Replacement: paso 5, imagen 3 de 3
    • Locate the four soldering joints for the power cord port found on the top side of the mother board.
    • Desolder the joints of the power cord port to release it from the motherboard.
    • Place the new power cord port into its original location and solder its joints.
    • Use the iFixit soldering and desoldering guide.
Conclusión
5 personas más completaron esta guía.
jeffrey555
Miembro Desde 09/01/15
424 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 16-3, Wollert Fall 2015 Miembro de USF Tampa, Team 16-3, Wollert Fall 2015
USFT-WOLLERT-F15S16G3
4 Miembros
16 Guías creadas
2 comentarios
Aonde compro essa fonte ? wagnerj957@gmail.com
wagnerjr1977 - Contestar
Ola moro no Brasil minha fonte queimou aonde compro outra?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 2,453
