Saltar al contenido principal
Amazon Fire TV Cube Speaker Replacement
Qué necesitas
  1. Amazon Fire TV Cube Speaker Replacement, Speaker: paso 1, imagen 1 de 3 Amazon Fire TV Cube Speaker Replacement, Speaker: paso 1, imagen 2 de 3 Amazon Fire TV Cube Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Speaker Replacement: paso 2, imagen 1 de 3 Amazon Fire TV Cube Speaker Replacement: paso 2, imagen 2 de 3 Amazon Fire TV Cube Speaker Replacement: paso 2, imagen 3 de 3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Speaker Replacement: paso 3, imagen 1 de 1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Speaker Replacement: paso 4, imagen 1 de 2 Amazon Fire TV Cube Speaker Replacement: paso 4, imagen 2 de 2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
Conclusión
2 personas más completaron esta guía.
Un comentario
Our volume pauses every 11 minutes! Troubleshooting our Sono’s System…still doing it. Could this be our Fire Cube?
Lee - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 3,290
