Introducción
These steps will guide you through the disassembly and the replacement of the Fire TV Cube motherboard. This guide requires the metal flathead spudger. Use extra caution when detaching wires.
Herramientas
Partes
No se especificaron partes.
Using a metal spudger, push down between the edge seals on the base and pry off the base.
Lift the black latch by gently prying up with the flat end of the Spudger.
Detach the copper tap by pulling it out.
3 personas más completaron esta guía.
