Saltar al contenido principal
Amazon Fire Phone Headphone Jack Replacement
Qué necesitas
  1. Amazon Fire Phone Headphone Jack Replacement, Front Panel Assembly: paso 1, imagen 1 de 1
    • If the display is damaged use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: paso 2, imagen 1 de 3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: paso 2, imagen 2 de 3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: paso 2, imagen 3 de 3
    • Power off your phone.
    • Remove the sim card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: paso 3, imagen 1 de 3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: paso 3, imagen 2 de 3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: paso 3, imagen 3 de 3
    • Press the single suction cup just above the home button.
    • While lifting up on the suction cup place the plastic opening tool at the rim of the screen, separating the screen from the back casing.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone, freeing the two halves.
  4. Amazon Fire Phone Headphone Jack Replacement: paso 4, imagen 1 de 3 Amazon Fire Phone Headphone Jack Replacement: paso 4, imagen 2 de 3 Amazon Fire Phone Headphone Jack Replacement: paso 4, imagen 3 de 3
    • Remove the 1mm screw concealed in the headphone jack.
    • Afterwards the headphone jack will easily pop off.
Conclusión
2 personas más completaron esta guía.
Savannah Moen
Miembro Desde 10/29/15
237 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 5-7, Maness Fall 2015 Miembro de Cal Poly, Team 5-7, Maness Fall 2015
CPSU-MANESS-F15S5G7
5 Miembros
10 Guías creadas
Un comentario
hello sir i need amazon fire back casing in Pakistan
Kashif Arif - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,873
