Saltar al contenido principal
Amazon Fire HD 8 Rear-facing Camera Replacement
Qué necesitas
  1. Amazon Fire HD 8 Rear-facing Camera Replacement, Screen: paso 1, imagen 1 de 2 Amazon Fire HD 8 Rear-facing Camera Replacement, Screen: paso 1, imagen 2 de 2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Rear-facing Camera Replacement: paso 2, imagen 1 de 1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Rear-facing Camera Replacement: paso 3, imagen 1 de 3 Amazon Fire HD 8 Rear-facing Camera Replacement: paso 3, imagen 2 de 3 Amazon Fire HD 8 Rear-facing Camera Replacement: paso 3, imagen 3 de 3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Rear-facing Camera Replacement: paso 4, imagen 1 de 3 Amazon Fire HD 8 Rear-facing Camera Replacement: paso 4, imagen 2 de 3 Amazon Fire HD 8 Rear-facing Camera Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Rear-facing Camera Replacement, Rear-facing Camera: paso 5, imagen 1 de 2 Amazon Fire HD 8 Rear-facing Camera Replacement, Rear-facing Camera: paso 5, imagen 2 de 2
    • Pop the camera out of the rear-facing camera casing by carefully pulling the orange cable with the tweezers.
  6. Amazon Fire HD 8 Rear-facing Camera Replacement: paso 6, imagen 1 de 2 Amazon Fire HD 8 Rear-facing Camera Replacement: paso 6, imagen 2 de 2
    • Flip up the tab on the ZIF connector at the end of the ribbon cable.
    • Grasp the underside of the orange cable with the tweezers and gently slide the camera out of the connector.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-3, Leahy Spring 2016 Miembro de USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
Miembros de 4
17 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 2,132
