Introducción
In this guide, we will show you how to replace the front camera. Before you start, make sure your device is powered off.
Qué necesitas
Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
Using a T4 screwdriver, remove the two screws situated on the left and right side of the camera.
Casi Terminas!
Conclusión
