Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Amazon Fire HD 7 (4th Generation) Motherboard Replacement
Qué necesitas
  1. Amazon Fire HD 7 (4th Generation) Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Amazon Fire HD 7 (4th Generation) Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Amazon Fire HD 7 (4th Generation) Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
    Pregunta a FixBot
    Agregar Comentario
  2. Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 2, imagen 1 de 1
    • Once all clips have been released, remove the back case to reveal the inside of the device.
    Pregunta a FixBot
    Agregar Comentario
  3. Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 3, imagen 1 de 3 Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 3, imagen 2 de 3 Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the nine silver screws located around the motherboard with the T5 Torx screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  4. Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 4, imagen 1 de 3 Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 4, imagen 2 de 3 Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 4, imagen 3 de 3
    • Remove the six black screws located around the battery and the speaker with the T5 Torx screwdriver.
    • Make your way around the battery and speaker to remove all of them.
    Pregunta a FixBot
    Agregar Comentario
  5. Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 5, imagen 1 de 3 Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 5, imagen 2 de 3 Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Carefully unplug the three wire connections by placing a plastic spudger under the connections and lifting up.
    • Disconnect the battery and speaker connections by placing the round handle spudger under the wires and lifting up and out.
    • Disconnect the display connections from the motherboard by using the plastic spudger to lift the clamp holding the ribbon cable. Then, using the tweezers, grab the ribbon wire and pull away from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  6. Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 6, imagen 1 de 2 Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the two screws holding the rear camera in place using the T5 Torx screwdriver.
    • Once freed from the screws, gently lift and remove the rear camera.
    • The camera lens is sensitive. Be careful when removing and handling the rear camera.
    Pregunta a FixBot
    Agregar Comentario
  7. Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 7, imagen 1 de 2 Amazon Fire HD 7 (4th Generation) Motherboard Replacement: paso 7, imagen 2 de 2
    • Now the motherboard is free to be removed.
    • Lift the motherboard up to remove it as shown in the picture.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 4-4, Passmore Fall 2016 Miembro de USF Tampa, Team 4-4, Passmore Fall 2016
USFT-PASSMORE-F16S4G4
Miembros de 4
10 Guías creadas
1Guía Comentario
I need to replace the stereo jack. Do I have to replace the mother board or is there a replacement jack?
Darin Guidry - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 48
Todo El Tiempo: 4,679
