Saltar al contenido principal
Amazon Fire HD 7 (4th Generation) Rear facing camera replacement
Qué necesitas
  1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: paso 1, imagen 1 de 3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: paso 1, imagen 2 de 3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: paso 1, imagen 3 de 3
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
  2. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: paso 2, imagen 1 de 1
    • There are an additional nine clips surrounding the battery area. Place the plastic tool into the clips and lift to disconnect them.
    • Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
  3. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: paso 3, imagen 1 de 1
    • Use a nylon spudger to unclip the connection from the motherboard.
  4. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: paso 4, imagen 1 de 2 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: paso 4, imagen 2 de 2
    • Unscrew the two screws using a T5 screwdriver.
    • The camera lens are sensitive. Be careful when removing and handling camera.
    • Once freed from the screws, gently lift and remove the camera.
Conclusión
Omir Rosado
Miembro Desde 09/30/16
725 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 4-4, Passmore Fall 2016 Miembro de USF Tampa, Team 4-4, Passmore Fall 2016
USFT-PASSMORE-F16S4G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 609
