Saltar al contenido principal
Amazon Fire HD 10 USB Charging Port Replacement
Qué necesitas
Instrucciones de Vídeo
Conclusión
To reassemble your device, follow these instructions in reverse order. Be sure connection pins (in the center of the pad) have enough solder to reattach the the replacement micro-usb.
12 personas más completaron esta guía.
eCuration
Miembro Desde 05/19/17
378,307 Reputación
236 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
140 Miembros
18,085 Guías creadas
3 comentarios
Can you use usb replacement parts for fire hd 6, 7 and 8.9 for the fire hd 10?
custmadehancraf - Contestar
Some English narration instead of the annoying music would be useful. Unsoldering looked rather magical, what was the heat source? Hot air gun under the board? You’re daubing on cleaner and flux, I guess, no idea what’s what. Paste solder?
Alan Corey - Contestar
Is there a way to know if it's the battery or the charging port
Tech Reviews - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 14,798
